LabWindows/CVI
undefined reference to ni845xFindDevice
I'm trying to use ni 845x driver to send i2c data. I'm trying to write a C application and see if the api calls work but I'm getting this following error
undefined reference to `ni845xFindDevice@12'
collect2.exe: error: ld returned 1 exit status.
I also cannot find example code for driver development in  C:\Program Files (x86)\National Instruments\NI-845x\MS Visual C
Below is my code for reference.
#include <stdio.h>
#include "C:\Program Files (x86)\National Instruments\NI-845x\MS Visual C\ni845x.h"
int main()
	char resource_name[256];
	NiHandle device_find_handle;
	uInt32 found_devices_count = 0;
	int32 tmp = 0;
	int ret = -1;
	tmp = ni845xFindDevice(resource_name, &device_find_handle, &found_devices_count);
    return 0;
(1,914 Views)
Accepted by topic author peace9795
You also need to add in your project settings the import library for this "driver". There should be a file ni854x.lib or similar in the same location as your header file or close to it. This needs to be added to your project.
Rolf Kalbermatter  My Blog
(1,869 Views)
