LabWindows/CVI
udp command line
I'm trying go get UDP work on command line application but it seems not working!
I was only able to get it work when using User interface application.
Is it normal?
(2,510 Views)
Hi Goncalo,
I am not aware of anything that would cause UDP communications to not work using a command line application. Would you be able to provide some more information on what version of software you are using and how you are calling this command line application?
Thanks!
ShaneK
(2,463 Views)
