LabWindows/CVI
How to move to next input box from one box by pressing an enter key only
I use 4 string Controls to input 4 serial number of 4 boards individually,but it must press Tab key to next input box.  I need to press an enter key to move to next input box only. I don't know how to do. Please see the attached file for my question specification
Thank.
(6,369 Views)
Accepted by topic author shunfu
I'd suggest making those input boxes "Hot" and in the callback function for the controls (on EVENT_COMMIT) you could use SetActiveCtrl() to move focus to the next control. The last one could send the focus on the button.
(6,352 Views)
Ian.W,
Thank you for your solution, and I have solved this problem by your support.
Thank.
(6,342 Views)
Another option is to use a table control. The table automatically moves to edit the next cell when the user hits the enter key.
I've attached a UIR with an example table. Note that the ATTR_AUTO_EDIT is enabled and
ATTR_ENABLE_COLUMN_SIZING is disabled.
Also, if you use the SetActiveCtrl() on the EVENT_COMMIT, you might get some unintended behavior. For instance,
- you only get a commit event if you make some change in the string control before hitting <enter>.
- you'll get a commit event if you make some change in the string control and then use the mouse to click on a different control. This case would probably be a weird user experience since the user might click on a previous control, but then your callback would make the next control be the active one.
- if the user does hit <tab> then you'll get a commit event, and that might interfere with your intended behavior.
(6,325 Views)
Good point about those potentially unwanted behaviors, Jared.
However in the past I have always found that input to a table has its own quirks that confuses some users. The ATTR_AUTO_EDIT attribute is helpful, but even then users might try to place the cursor within the text of a selected cell to make a correction. Unless they double-click first that second (slow) click won't work, and to them the cell seems uneditable. (In Excel the formula bar accepts that cursor-placing click, but in a CVI table we do not have the equivalent of the formula bar.)
That said, the table may still be a better choice, especially if one does not catch other events beyond EVENT_COMMIT and refine the textbox behavior accordingly.
(6,315 Views)
Yeah, I agree that getting the table into edit mode could be a little quirky for the user. In this case, it would be nice if the table were always in edit mode. Having a table callback like this would help....
static void ActivateNextTabOrderCtrl(int panel, int control)
	int nextCtrl;
	GetCtrlAttribute(panel, control, ATTR_NEXT_CTRL, &nextCtrl);
	if (nextCtrl == 0)
		GetPanelAttribute(panel, ATTR_PANEL_FIRST_CTRL, &nextCtrl);
	SetActiveCtrl(panel, nextCtrl);
static void ActivateNextTabOrderCtrlIfNecessary(int panel, int control)
	Point activeCell;
	int numRows;
	GetActiveTableCell(panel, control, &activeCell);
	GetNumTableRows(panel, control, &numRows);
	if (activeCell.y == numRows)
		ActivateNextTabOrderCtrl(panel, control);
static void ActivatePrevTabOrderCtrl(int panel, int control)
	int numCtrls, currentCtrl, tabPosition, targetTabPosition;
	GetCtrlAttribute(panel, control, ATTR_CTRL_TAB_POSITION, &targetTabPosition);
	GetPanelAttribute(panel, ATTR_NUM_CTRLS, &numCtrls);
	if (targetTabPosition == 0)
		targetTabPosition = numCtrls-1;
	else
		targetTabPosition--;
	GetPanelAttribute(panel, ATTR_PANEL_FIRST_CTRL, &currentCtrl);
	for (int i=0; i<numCtrls; i++)
		GetCtrlAttribute(panel, currentCtrl, ATTR_CTRL_TAB_POSITION, &tabPosition);
		if (tabPosition == targetTabPosition)
			break;
		GetCtrlAttribute(panel, currentCtrl, ATTR_NEXT_CTRL, &currentCtrl);
	SetActiveCtrl(panel, currentCtrl);
static void ActivatePrevTabOrderCtrlIfNecessary(int panel, int control)
	Point activeCell;
	if (activeCell.y == 1)
		ActivatePrevTabOrderCtrl(panel, control);
int CVICALLBACK TableCB (int panel, int control, int event,
						 void *callbackData, int eventData1, int eventData2)
	int runState;
	switch (event)
		case EVENT_ACTIVE_CELL_CHANGE:
		case EVENT_GOT_FOCUS:
			GetCtrlAttribute(panel, control, ATTR_TABLE_RUN_STATE, &runState);
			if (runState != VAL_EDIT_STATE)
				SetCtrlAttribute(panel, control, ATTR_TABLE_RUN_STATE, VAL_EDIT_STATE);
			break;
		case EVENT_KEYPRESS:
			if (eventData1 == VAL_ENTER_VKEY || eventData1 == VAL_TAB_VKEY)
				ActivateNextTabOrderCtrlIfNecessary(panel, control);
			else if (eventData1 == (VAL_SHIFT_MODIFIER | VAL_TAB_VKEY))
				ActivatePrevTabOrderCtrlIfNecessary(panel, control);
			break;
	return 0;
(6,309 Views)
Thanks, Jared!  Next time I need table input I'm going to try this out.
Ian
(6,282 Views)
