LabWindows/CVI
type size issue
I have a numeric control. The type is unsigned int(0- 4 294 967 295). I try to get the value in an unsigned int variable with GetCtrlVal() but when the value is upper than 2 147 483 647, the value is negative. There is a mismatch between the two types. I tried to use unsigned long int, same problem.
Somebody already had this problem? Or somebody know how I can solve my problem.
Thanks everyone.
(3,826 Views)
I tried to reproduce what you have described but could not succeed in observing the same behaviour.
If I set the control type as unsgined int and pass an unsigned int variable to GetCtrlVal function, it works as expected.
If you see a negative sign that means the variable is signed, so be sure you pass the correct variables.
S. Eren BALCI
IMESTEK
(3,813 Views)
Maybe the problem happens in my version. I'm using Labwindows/CVI 8.1.1
I checked my variables, they are Unsigned int, and when I display the value (printf), I have the negative one. I can do what I want even with this problem, but it's embarrassing.
Thanks for your help and your time.
(3,808 Views)
are you sure that you use the correct format specifier in printf?
(3,806 Views)
wooooowwwwww!!! So many years I program in C code, and I discover %u to display an unsigned int. :s
I am so sorry. Thanks a lot for your help. I ashamed, but you are very helpful. 😄
(3,804 Views)
don't worry, it happens Smiley Wink
(3,801 Views)
Johandball,
Something like this might help you with format types 😉
http://msdn.microsoft.com/en-us/library/75w45ekt(v=vs.80).aspx
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindowsâ„¢/CVI Developer
Neosoft Technologies inc.
(3,796 Views)
