LabWindows/CVI
tree scroll bar
Is there a natural way of having an horizontal scroll bar on a tree control which keeps the tree (the first column) allways visible ?
If this is not possible, do you think it would be easy to keep 2 tree controls "synced" to have an equivalent behaviour ?
Best regards.
(4,660 Views)
Hello crazyfwed,
To sync the scroll of 2 tree controls you could put in the control callback for both trees some code similar to this:
int CVICALLBACK TreeCB (int panel, int control, int event,
						 void *callbackData, int eventData1, int eventData2)
	int s;
	switch (event)
		case EVENT_VSCROLL:
			GetCtrlAttribute(panel, PANEL_TREE, ATTR_VSCROLL_OFFSET, &s);
			SetCtrlAttribute(panel, PANEL_TREE_2, ATTR_VSCROLL_OFFSET, s);
			break;
	return 0;
 If you want to sync also the selection, you could handle EVENT_SELECTION_CHANGE:
		case EVENT_SELECTION_CHANGE:
			SetTreeItemAttribute (panel, PANEL_TREE_2, eventData2, ATTR_SELECTED, eventData1);
			break;
Constantin
(4,653 Views)
