LabWindows/CVI
timer function
May i know how to use the timer function in labwindows so that i can read a value from my 6024E card very 2ms?
what is the program to write in order to achieve this?
(3,298 Views)
You cannot rely on software timer to guarantee constant pace under windows, especially with so short times as you request.
To obtain a timed acquisition with a daq card you can rely on internal timing hardware, setting up a continuous acquisition at 500 sample/sec rate.
In case you need to acquire a specified amount of time and you can manage measures after acquisition is ended you can look at buffered acquisition functions; in case you need manage measures while acquisition is in progress you should use double-buffered acquisition.
In any case take a look at the examples shipped with ni-daq: they can give you a framework with which to customize your application.
Hope this helps
Roberto
(3,298 Views)
