LabWindows/CVI
tfestimate math function
I am analyzing the frequency response of a system and converting the process from MatLab to C in LabWindows. I need to use the math function tfestimate. I found a solution for LabView using scripts, is this available in LabWindows? Is there a solution for using tfestimate in LabWindows?
(3,731 Views)
I sent you a response via email, but I will post it here as well.  The TransferFunction is the only function available in CVI (natively).  Your best bet would be to find the .dll that contains this function and import that, along with the header file, into CVI and call the function that way.
Sean
Applications Engineering Specialist - Semiconductor Test
(3,716 Views)
