LabWindows/CVI
stdbool.h ?
Hi all,
I would like to use Bool type... and so I was looking for the stdbool.h.
It isnt part of the ansi-c library ?
thanks, David
(4,525 Views)
No, the boolean data type is not defined in the ANSI-C specification and is not available in CVI.
Best Regards,
Chris Matthews
(4,525 Views)
Hi David,
There is not a boolean data type in the C language; it does not have the traditional view about logical comparison, but that's another story. On the other hand, recent C++ compilers (such as Borland and Visual c++) do have a boolean datatype.
One common way to work around this limitation is to type-define your own boolean data type. For example,
typedef unsigned char bool; // use only one byte of memory
OR
typedef unsigned int bool;
Azucena
(4,525 Views)
is part of the latest C99 standard (ISO/IEC 9899:1999).
It seems LabWindows/CVI only supports the older C89 standard.
(4,525 Views)
