LabWindows/CVI
static type check
void demo(int a[][64])
int main(void)
	int b[20][128];
	demo(b);
	return 0;
Look at this simple source code, LabWindows/CVI's C compiler just let it pass without even a warning! From this we can see how weak the static type check function of LabWindows/CVI is. If there is any switch to open a stronger check mode, please tell me. However, since the compiler speed is already very slow, I think open that function will make it too slower.
(4,895 Views)
Accepted by Jim88888
That depends on the version of CVI and your Build settings... With CVI2013f1 and warning level set to Common I get
warning: incompatible pointer types passing 'int [20][128]' to parameter of type 'int (*)[64]'
(4,892 Views)
Thank you very much for your reply. I'm using CVI2012, I opened all check mode, as the following picture shows:
I still got nothing. I'm not very familiar with LabWindows so I'm not sure if there is any other switch. Maybe I should compile the project using another compiler before build CVI project, if it's possible.
At last , thank you again.
Best regards.
(4,886 Views)
The major difference between CVI2013 and CVI2012 is that the new version uses a different/better compiler (clang). You can use (an old version of) clang in CVI2012, too, as an external compiler (for the release build).
See here to get started.
(4,878 Views)
