LabWindows/CVI
split source window gone in CVI 2019?
maybe I go blind - but I am not able anymore to split the source window in the IDE.
No behaviour change is indicated in the readme, and also the help still mentions the use of subwindows.
Did someone manage to use a split screen in CVI2019, and if so, how?
Thanks!!
(3,432 Views)
Accepted by Wolfgang
You'll need to go to the rightmost of the window, just above the scrollbar. You'll see that there is a small rectangle and the cursor changes when you're over it. I can attach a print screen if you still don't find it.
(3,418 Views)
Thanks a lot, I've found it Smiley Happy
May I suggest to update the documentation? The help still says
To create a subwindow, double-click the thin line beneath the menu bar or toolbar.
This was the behaviour in previous versions, but now there is no thin line anymore, obviously this is one of the new features of the new editor.
(3,403 Views)
Sure, I'll create a work item for that. Smiley Happy
(3,398 Views)
