10-10-2007 11:52 AM
10-15-2007 04:53 AM
Hello Sebastian,
I do not think that you are at the limit of the device.
The USB-6008 is a "slow" device but from its specifications still operates at over 150 Hz for analog output or 10 kHz for analog input. If you look into another thread (timing problem application using DAQmx functions, http://forums.ni.com/ni/board/message?board.id=180&message.id=31611) you see people working at a rate far over 100 Hz. My application does include adding data points to a stripchart. Note that the update is even faster than the refresh rate of the monitor.
My suggestion: try you application where you disable a few plot commands or output commands or ... ... by commenting these lines with // and find so the bottleneck for the slow (< 1 Hz) update speed.
Succes, Jos
