LabWindows/CVI
setctrlmenuattribute
Bonjour Smiley Happy,
j'utilise la fonction SetCtrlMenuAttribute pour mettre un item de mon menubar checked
Spoiler
void CVICALLBACK CB_Administrateur (int menuBar, int menuItem, void *callbackData,int panel) {     SetCtrlMenuAttribute (panel, menuBar,  menuItem, ATTR_CHECKED, 1);   }
ça m'affiche un message d'erreur: je comprends pas le source ou comment le résoudre
Spoiler
NON-FATAL RUN-TIME ERROR:   "SFT015AET.c", line 546, col 1, thread id 0x00001064:   Library function error (return value == -139 [0xffffff75]). Controls of the type passed do not have a menu
(3,802 Views)
Accepted by FibiIA
Hello, I'll answer in English...
SetCtrlMenuAttribute is destined to manipulate menus owned by particular controls like tables or others. To manipulate menu bars you must use SetMenuBarAttribute instead.
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(3,799 Views)
SetCtrlMenuAttribute is for control menus - not for menu bars... here you should use SetMenuBarAttribute Smiley Wink
(3,798 Views)
hi,
sorry for talking in frensh.
Thank you, that's what i ware searching for.
(3,793 Views)
