LabWindows/CVI
set default for all controls
How do I set a default for all controls?
For example, I want the label to always appear on the left.  Instead of setting the control attribute for each LED separately, I'd rather set a default to be applied to all LEDs.
I'd prefer to do this programmatically.
Thanks!!!
(3,046 Views)
one possibility is to use the function call SetAttributeForCtrls from the programmer's toolbox library.
Another, to generate the controls programmatically - if you are using your own functions to do so you can define the default as to your liking.
Wolfgang
(3,044 Views)
