LabWindows/CVI
send file to serial port using comfromfile
Thanks for your support...
Anyhow as of now we are using hypertermial as solution for our work...
Message 11 of 24
(2,099 Views)
Hello Vikram,
Did you catch it when Roberto wrote : "I'm not sure I can understand what is happening there, but it seems to me that you have saved the same log with different names: attached files are identical (fc found no differences: they are byte-by-byte the same)"
Did you really post the files you planned to post ?
Message 12 of 24
(2,098 Views)
Ok..it's mistaken
Please find the log of hyperterminal commands
Message 13 of 24
(2,091 Views)
There is 1 difference (44th character sent...that's the only difference) as you can see below :
undefined
Message 14 of 24
(2,086 Views)
Erratum : 45th character sent (index 44 in 0-based index array)
Message 15 of 24
(2,086 Views)
It seems that there is an answer from the controller (*0) in the middle of the frame for Hyperterminal (after 44 characters have been sent). Maybe you should read this answer before sending other characters to COM port ?
undefined
Message 16 of 24
(2,081 Views)
I had cross checked that..and executed one more time freshly...
please find the log..even i surprised..why in between the response came in that file..
see the new log..there is no change in the data
Message 17 of 24
(2,077 Views)
I guessing on the Data format and internal configuration of CVI..
my rs232 configuration is( buadrate 115200, data bits 7 and parity odd & stop bit 2)..
I am thinking the data bit is 7 in configuraiotn but sending one byte(8 bits)..I am totally confused what to do with this behavior.
Message 18 of 24
(2,075 Views)
You're right.
Another point is "IOCTL_SERIAL_SET_TIMEOUTS" lines in CVI log, between each character sent. It is not visible in HYP log. Don't you think it could be the reason why it doesn't work ?
Message 19 of 24
(2,074 Views)
About COM configuration : don't you have any documentation with your controller ?
Message 20 of 24
(2,073 Views)
