Is there a function to select multi-folder in the popup windows(just like MultiFileSelectPopup)? I found DirSelectPopup but can only select one folder at a time. If not, is there any way to work around it? I have a series of folders with the same structure. I want to load several folders in the popup window and display the comparison plots. Right now I have to add the folders one by one into a list box and run the loop.
wmf
