LabWindows/CVI
select multi-folder in the popup window
Is there a function to select multi-folder in the popup windows(just like MultiFileSelectPopup)? I found DirSelectPopup but can only select one folder at a time. If not, is there any way to work around it? I have a series of folders with the same structure. I want to load several folders in the popup window and display the comparison plots. Right now I have to add the folders one by one into a list box and run the loop.
wmf
(3,169 Views)
Hello wmf,
Unfortunately, there is currently no function built into CVI to allow you to select multiple directories from a file dialog. It sounds like you have a potential work around -- the only *fancy* way I can think of would be to use the Windows SDK, but that might involve mork work than it's worth. Nevertheless, you can try looking through the dialog functions available. I'd suggest making a product suggestion:
Best of luck!
Charlie S.
Visit ni.com/gettingstarted for step-by-step help in setting up your system
(3,145 Views)
