LabWindows/CVI
__security_check_cookie
Hello -,
I am trying to develop a data acquistion/collection using CVI/LabWindows 8.1.
I added all the required include and lib files.
But I get error in linking.
The link errors is about "security_cookie", and "security_check_cookie".
I tried to disable it using the compiler flag "/GS-", but didn't work.
I need your help please.
I attached a png file with the errors.
Thank you for responding me promptly.
Farideh
(6,175 Views)
Hello Farideh,
Try including in the project niDCPower.fp rather than nidcpower.lib. According to this it is located in <IVIROOTDIR32>\Drivers\niDCPower\niDCPower.fp
Also this article suggest inlcuding bufferoverflowU.lib. See if you have this lib.
Constantin
(6,163 Views)
Hi Constantin,
Once I added the instrument file "nidcpower.fp", the CVI 8.1 complained that it cannot read the format of the function panel with an older version of CVI.
The NIDCPower driver I installed is 15.5 version.
What version of NIDCPower should I install with CVI 8.1?.
Thanks.
As well the bufferoverflowU.lib was found and did not resolve the issue with Security_cookie.
Thanks again.
Farideh
(6,154 Views)
Hello Farideh,
Indead, in the readme it says NI-DCPower 15.1 supports LabWindows™/CVI™ 2012 or later. It seems that version 1.4 is the last one that suports CVI 8.1. Version 1.5 supports LabWindows™/CVI™ 8.1.1 or later. If you have CVI 8.1.1 you can use NI-DCPower 1.6
Constantin
(6,137 Views)
Accepted by ffarahnak
Hello ,
Thank you for assisting me in resolving the issue. It is being resolved.
Thank you again. Kudos.
Farideh
(6,053 Views)
