LabWindows/CVI
sectioning a graph
Hello. I have a question making different colored sections of a graph. I currently have a graph set up in my .uir and I use PlotLine to display three different lines on the graph. I wanted to know if there's a way to divide the graph into 3 sections. I am displaying 3 phases of a cycle on a machine and horizontally I would like to have the graph backgroud be light gray from 0 to 60 secs, white from 60 to 240secs, and light gray from 240 secs on. Is there any way to do this? If not, I thought I might have to make three separate graphs and display them side by side. Any help would be greatly appreciated. Thanks, Jason
(3,147 Views)
Jason,
The best way I know of to do this is to create a bitmap (I just used Microsoft Paint, it works well)using the pattern/colors you want, and load this into a Picture control. Then position this behind the graph, and make the graph transparent using the following tip in this KnowledgeBase article:
http://digital.ni.com/public.nsf/websearch/8F5D605F1941771A86256B29000B7FE0?OpenDocument
Hope this helps!
David McClelland
(3,147 Views)
From your description, it seems that making three calls to PlotRectangle, passing it different colors each time, should do the trick. Would it?
Luis Gomes
NI
(3,147 Views)
