LabWindows/CVI
screen capture durin run time.
hello everyone,
ill be short and i hope someone will know how to help me.
I have an application, in wich in its end, i want to make a screen capture after hiding the main panel.
Meanning i dont need the panel`s capture, but the windows and whatever programs are working at that time.
Plus i need the screen capture photo in a bitmap/jpg/atc. file.
thanks in advance,
Adi.
Message 1 of 8
(5,650 Views)
Hello, you could use GetPanelDisplayBitmap and SaveBitmapToPngFile (or to other file format like jpg: look at available functions in the help)
Message 2 of 8
(5,644 Views)
Just reading your post better and my answer is not what you are looking for.
Take a look at this thread and at NickB code in this other one
Message 3 of 8
(5,642 Views)
Not sure i can use these previos posts...
hope i just didnt miss understand it.
I need the screen capture to happend by it self.
The operator presses a command botton that generats few thing, then hides the panel - and only then takes the screen shot...
I dont want the operator to be involved in the capture process.
But i do need it in a file.
thanks.
Message 4 of 8
(5,630 Views)
i just need hiding the panel
and saving a screen capture
there is my spesific code :
HidePanel (panelHandle);
keybd_event(0x2C, 0, 0, 0);
ClipboardGetBitmap (&image, NULL);
SaveBitmapToJPEGFile (image, machinestr3, 0, 100);
QuitUserInterface (0);
I keep getting things I dont understand why they happen.
first one after saving my code and running:
NON-FATAL RUN-TIME ERROR: "NewScap.c", line 449, col 17, thread id 0x0000255C: Library function error (return value == -127 [0xffffff81]). Bitmap is invalid
then when i press again on run - it runs perfect the first time,
then when i run again and again I keep getting the screen capture of time I pressed the first time.
plz help i am a bit frustrated.
tnx Adi.
Message 5 of 8
(5,615 Views)
I have problems myself with this function, even though different from yours. In my case it keeps saving simply the previous image pasted to the clipboard: that is, if I execute the function at 9:00:00 it saves the screenshot taken e.g. at 8:58:00; next time it will save screenshot taken at 9:00:00 and so on.
I supposed I am simply too fast in saving the image: in effect adding a small delay corrected the problem.
The complete function, with error trapping added, is the following:
int		avail, bitmap = 0, error = 0;
char	msg[512];
// ... other code here
keybd_event (VK_SNAPSHOT, 0, 0, 0);
DelayWithEventProcessing (1.0);  // Delay added
ClipboardGetBitmap (&bitmap, &avail);
if (!avail)
    MessagePopup ("Warning", "No bitmap available in the clipboard!");
else
    error = SaveBitmapToPNGFile (bitmap, "c:\\temp\\bitmap.png");
// Clearing resources and error warning
if (bitmap) DiscardBitmap (bitmap);
if (error < 0) {
    sprintf (msg, "Error %d found:\n%s", error, GetGeneralErrorString (error));
    MessagePopup ("Warning", msg);
Check your situation and see if this workaround can fix your problems too.
Message 6 of 8
(5,597 Views)
THANK YOU VERY MUCH !!! Smiley Happy
And the part i needed the most is indeed the delay function....
It solved 3 problems i had.
(i am writing it so if more ppl would get in trouble with it)
1.At initial run it couldnt find the bitmap, and the application kept crushing down, i guess its like u wrote - that was too fast.
2.The image i got was of previos run not corrent run.
3.The images were saved with the application`s panel in it.
here is the code I finaly used :
//...........rest of code
keybd_event(VK_SNAPSHOT, 0, 0x0001, 0);
SaveBitmapToJPEGFile (image, "IMAGE_NAME", 0, 100);
{ill take the error traping to another place in my code 🙂 }
Thank you very much Mr. Bozzolo.
I hope this post would help more ppl.
Adi.
Message 7 of 8
(5,588 Views)
Good to know you've solved your problem Smiley Happy
Another hint I can give you: if the panel has elementos with a transparent background (labels, pictures and so on) you will receive errors in SaveBitmapToJPEGFile since jpg format cannot handle transparency: in this case you can use png format and the corresponding SaveBitmapToPNGFile.
Message 8 of 8
(5,585 Views)
