LabWindows/CVI
Showing results forĀ
Search instead forĀ
Did you mean:Ā
sample rate?
I run the sample program "ai_samp.prj" in the path "easyio".
I set the smaple rate to 1000Hz,but the acutal smaple rate shows 400Hz.I
want to know why.
(4,048 Views)
Shen,
This question is answered HERE [broken link removed].
Good luck with your application.
Spencer S.
(4,048 Views)
Spencer S,
Thank you.
I want to sample data and show it on the screen at the same time
continuously .How can i do? Are there any examples? I'm a beginner.
Shen
(4,048 Views)
Shen,
Absolutely. If you want to continue using the Easy I/O functions, the ai_async.prj example both continuously acquires and graphs.
Spencer S.
(4,048 Views)
Thank you.But ai_async.prj is an asynchronous one.
If I need a synchronous one to achieve high sample rate, do I need extra
hardware in windows2000?
(4,048 Views)
Synchronous Vs. Asynchronous is a "concern" when dealing with finite operations, not continuous as you have indicated you want to perform. With regards to speed, I would suggest that you create your application based on the DAQdoubleBuf.PRJ example available in the following location:
C:\Program Files\National Instruments\MeasurementStudio\CVI\samples\daq\Ai
This example does not have a user interface, but I have attached an example I created sometime back that acquires continuously from multiple channels and displays the data on a user interface.
Good luck.
Spencer S.
(4,048 Views)
