LabWindows/CVI
same read from 2 threads
Hi People!
   I'm developing an application dealing with digital I/O. I have two tasks, one for Input channels, one for outputs.  In my application I've also 2 threads.
   my question is: can I perform a DAQmxReadDigitalU8() function, associated with the same task, (say, taskHanlder_1) form the 2 different thread? Can this cause collisions? I mean, if the 2 threads runs "simultaneously" (it is actually impossible, of course on a single processor system), and both perform Read function, what does it happen?
   I'm asking this because I've poor means to test this behaviour...
   Thanks!
graziano
(4,957 Views)
Ciao Graziano,
if I get you right, you are willing to use the same DAQmx Task from 2 separate threads (ideally simultaneous). I am not sure this is possible.
DAQmx is multithreaded, so there is no problem in accessing the DAQmx Driver from 2 different threads at the same time in parallel.
The thing that sets me off is using the same Task (i.e. the same board resources) in 2 different places at the same time.
What do you mean by " I have poor means to test this" ?
You could put together a piece of software that tries to open the same task from 2 different threads on a device.
Could you post an example here?
AlessioD
(4,930 Views)
You might want to design your system to read the daq channel from only one of the threads or from it's own thread.  When a read occurs use a thread safe variable or a thread safe queue (or even a queue for each receiving thread) to pass the data along.  That way possible collisions will be minimized.
(4,927 Views)
Hi mvr,
  of course your solution is good, in common applications, I've thought too, but....
    I'm developing a driver. A 3-rd party application should call functions such as READ and WRITE (Read and write Digital values), and my driver should implement them.  More, the driver should have a thread that continuously "listen" upon 2 lines (to simulate  interrupts).   The easyest way is having 2 threads.  In this way I can perform "simultaneously" a READ DIGITAL IN function and  I can listen to the interrupt lines.
       Note: the application which calls these function is an old program running on an emulated PDP11!!!! So pdp11 emulator (running in Windows) has a standard interface to develop drivers for new PCI devices (my NI 6509) that should emulate older devices (DEC DRV11  parallel interface, produced by Digital).
   That's why I can't use your solution:  the 2 thread system can lead to not-acceptable timings  in I/O operation.
   I've posted my question in another NI board, and the answer was that I can  do it (2 reads from 2 threads).
      look: http://forums.ni.com/ni/board/message?board.id=70&message.id=4451#M4451
  it's a NI answer!
  My best whish is to say "I love Digital and the glorious pdp11!".....
graziano
(4,924 Views)
Very interesting application.  Amazing that legacy PDP-11 code can be adapted to todays hardware.
Good Luck!
(4,917 Views)
Hi mvr,
   thanks for your interest in this application!
   If you're looking to some infos....
   http://www.softresint.com/charon-11/
   pdp-11 was used in many industrial process-control tasks, and was considered reliable, partly due to good RT operating systems.
   Bye, and have a nice day!
graziano
(4,904 Views)
I think a PDP 11/44 was the first system I ever worked with.  A long time ago now.  I have not seen one in years, but got a real kick out of knowing that there is still some of that legacy code in use.  Thanks for the link.
(4,884 Views)
