LabWindows/CVI
runtime installation: unknown error, details box: No details available
Hi, when I try installing the run time on a couple different computer on my network I get this error message right after the installer finish extracting files: an exlamation mark in a yellow triangle and Unknown Error
I can press OK and the installer close or I can click details and when doing so in the details msg box I have: No details available
The installer close and nothing install.
I tried running the autorun from C:\National Instruments Downloads\NILWCVIRTE2009SP1 this does pop up the screen but when I choose to install the runtime I get the same error box.
I have tried with different account on different computers (domain or local administrator accounts) and nothing change I always get this error.
i tried 2 different version of the latest runtime with same result but if I install the runtime version 8 it works fine.
here is the 2 file I downloaded from NI website:
NILWCVIRTE901.exe                     size:   60,058,144 bytes
NILWCVIRTE2009SP1.exe             size:  125,556,832 bytes
I got that problem also when trying to install a package that has been compiled by labwindows 9 wich includes the standard runtime, as soon as the setup start I get that unknow error so I'm guessing that error comes from the runtime error.
Any help would be appreciated.
(5,045 Views)
Hi cividan,
I am a little confused as to what the error is. Can you send a screenshot of it?
Thanks!
Chris T.
(5,007 Views)
Here is a screenshot of the error I receive. In case I didn't mention it I tried installing the application using both local administrator and domain administrator account and nothing change, always same error message.
(4,988 Views)
I wonder...
(1) Try putting the installer files in a folder directly off the root, where the folder name contains no spaces (e.g. C:\CVIRTE2009SP1), then running it from there.
(2) If that doesn't work, try using subst to assign a drive letter to the folder containing the files:
subst z: "C:\National Instruments Downloads\NILWCVIRTE2009SP1"
then run z:\setup.exe.
(3) If that doesn't work, try copying the files to the root of a memory stick and running from there.
Martin
Certified CVI Developer
(4,980 Views)
(1) no luck
(2)  no luck here either
(3) no good either
would have been very surprising if that would have work but it was worth a try...
(4,975 Views)
Accepted by topic author cividan
Hi cividan,
Can you run the installer from command line and do a log?
Instructions can be found here:
http://digital.ni.com/public.nsf/allkb/AB597E885DB7D16B86256E92006DB232
Thank you!
Chris T.
(4,928 Views)
Hi, I found what was causing the problem,the problem comes from my antivirus (Fortinet Forticlient 4.2.0.250) if I shutdown the antivirus the setup start as it's supposed to but if I turn the antivirus back on the problem reappear when I try to Install NI product. Thanks for the help.
(4,883 Views)
