LabWindows/CVI
retrieving data from access database
Spoiler
I have a simple database called mydb.  I am trying to retrieve data from a table in the database called SN_data.  I am trying to retrieve a serial number (long int) from SN where ID = 1.  I can find the record but cannot display the data.  Is there a simple example that demonstrates retrieving data?
(4,769 Views)
By searching in the examples with "SQL" keyword you will be prompted with several examples (readtab, readtab2, readtab3) that shows you alternatives to find and read records from a database. Readtab3, which uses random acces and maps, is probably the example that is more useful for your needs.
(4,734 Views)
I have an example running.  Is it possible to run a query that is defined in an access database from CVI and obtain the results from it without generating the query in cvi?
(4,721 Views)
I cannot answer on this as I'm not using MS Access databases.
(4,706 Views)
