08-18-2009 02:18 PM
I do not know what NI was expecting to accomplish from remote debugging, but from my point of view what is offered is useless. I followed the white paper about getting started with LabWindows/CVI Remote debugger. I got the application running on the debuggee and the debugger on my development computer says it is running on the debuggee ip address.
However, from the debugger you do not see any of the front panels, so no user events can be generated from the debugger. I can't reach the code that I want to debug unless I go to the debuggee and press the front panel button. If I have to walk back and forth between the debuggee and the debugger, I would be better off moving my development enviroment to the debuggee.
A better solution would be to get a debug license for the target computer, load pcAnywhere on both the target and my development system. Then you can sit at your development system and debug directly in the LabWindows/CVI enviroment.
08-18-2009 03:42 PM
I sorta agree. I have used remote debugging to solve the problem of not having a full development CVI installed on a target. I have a CVI FDS on a laptop, and I walk up to the target system (a test station) and cable up directly then run remote debug. I am able to manipulate the target app GUI directly 'cause I'm right next to it. You can try to do it with remote terminal on Win32 machines, but I agree it's easier if I'm right there. In fact, I've never used remote debugging except for the scenario I just described. And it can be frustrating coordinating all the arcane stuff you've got to do to get it going - I usually wind up rebooting a lot, restarting CVI, etc.
Menchar
08-19-2009 03:00 PM
So all this time I've been using it to debug has been wasted?
When the debugee has no CVI on it, it comes in real handy.
But that's just from my point of view.
Thanks, NI.
08-19-2009 03:06 PM
08-20-2009 02:13 AM
For my,remote debugging is very nice and useful feature.
It is nice and easy to load debugee version of app, configure remote adres, and run debug.Without instalation of full
Development enviroment(withh liccense aktivation) always when i need find litle bug.
Typical situation when i use remote debuging:
1)When i need litle debuging, on target PC mashine with NI Cards +special HW
2)When there is a problem specific for Win version(or settings), or PC hardware(specialy notebook)
(on development system, all works ok, so i need debug on target PC)
When i need remote control of app, i use something like UltraNC or Windows remote Desktop SW.
08-20-2009 02:41 PM
08-20-2009 02:49 PM
08-28-2009 12:26 PM
Hi Paul,
I agree that remote debugging is useless if your application has a UI and you cannot interact with the UI at your local station. The idea behind remote debugging is that you would also be using something like Windows Remote Desktop/Assistance to connect to the remote computer so that you can interact with the UI.
Of course, if you're able to install the CVI ADE in the remote computer, and you can still reproduce the problem that you're trying to debug when running the source code from the ADE (which is not assured, since some bugs can be very fickle) then you probably have no need for remote debugging.
Luis
08-28-2009 12:48 PM
The problem with installing the CVI IDE on every target is licensing.
When you have a large number of target systems, all running the CVI app, and all of which may produce unique problems requiring debugging, what do you do? Buy a dozen copies of CVI FDS, one for each target? While I'm sure NI thinks this is a fine idea, I don't.
Furthermore, having the IDE installed on every target can mask poorly prepared distribution kits. Resources left out of the distribution may in fact be on the target due to the IDE's presence. If you then ever need to distribute onto a target without the IDE, you'll discover the hard way that everything required wasn't in the distribution 😉 Then you realize that if the IDE versions weren't identical, your deployed application was depending upon multiple versions of supporting resources that may be generating version-dependent errors 😉 In short, you can wind up with a deployment nightmare.
I've had trouble getting the TCP link between the target and the debug host to fire up and/or restart properly . I've had trouble when trying to restart the debug session on the host, I always seem to wind up having to restart everything on the target and the debug host. And if you're also using remote terminal / PC anywhere or some such to see the target GUI from the debug host then it's even more complex. It's flaky enough that I use remote debugging only when I absolutely have to.
Menchar
08-28-2009 03:52 PM
