LabWindows/CVI
refresh graph
Using Labwindows/CVI 8.1.0 on Windows XP.
I have a "virtual o'scope" graph display on a panel, and a parameters setup panel that, among other things, allows me to set the background color for the graph.
After returning from the setup panel I call :
    // Set the scope BG color.
    SetCtrlAttribute(iHandle_VOscope,VSCOPE_SCREEN,ATTR_PLOT_BGCOLOR,(int)G_VOscopeSetup.item[OSCOPEBGCOLOR].nvalue);
and then
    status = DisplayPanel (iHandle_VOscopeSetup);
to refresh the screen.
The problem is that the background color on the graph doesn't change unless I close the window and reopen it. I've also called
        RefreshGraph (iHandle_VOscope, VSCOPE_SCREEN);
after setting the background color, and that doesn't work either.
Any suggestions would be appreciated.
(3,553 Views)
Did you try ProcessDrawEvents?
RefreshGraph isn't expected to work here because it only redraws plots.
(3,549 Views)
Nope, ProcessDrawEvents doesn't do it either. The funny thing is that if I put a breakpoint in after the set-parameters panel exits (I hit the "Done" button, and it calls the SetCtrlAttribute function) it redraws the background.
(3,545 Views)
(banging head softly against wall, so as to not damage the plaster)
When I closed the setup panel, I was saving the new settings from the panel to the common structure (where the main panel could find them) _after_ I refreshed the main panel. Amazing what happens when you do things in the right order.
(3,535 Views)
