LabWindows/CVI
recent file pulldown menu
Is there a reasonable method of coding a "most recently used file" pull
down menu. All the ways I can think of a fairly complex.
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(3,449 Views)
There is a complicated example in the Sample CVI files (I can't remember the exact path). However, I have successfully used the 'List' functions (either toolbox or utility functions as I recall) to implement a recent files list, after a fashion.  The basic idea was as follows:
struct MenuList
       ListType FilePathList;  // full file path
       ListType FileMenuList;  // abbreviated path for display on menu
       ListType FileMenuID;       // identifier for each menu entry of full and abbreviated paths
      }     RFL;
char pathname[MAX_FILENAME_LEN], display_path[MAX_PATHNAME_LEN];
int entry_ID;
static int prev_entry_ID; // (use ListGetItem for this)
//  Break up 'pathname' using pointer manipulation, strcpy, strstr, strcat, or strtok, etc. e.g. C:\Data...\test.dat
// add to menu and assign a custom callback function (e.g. 'OpenRecentFile'), which uses RFL structure for information on path...
 entry_ID = NewMenuItem (Menubar, MenuID, display_path, prev_entry_ID, 0, OpenRecentFile, RFL);
 SetMenuBarAttribute (Menubar, entry_ID, ATTR_CHECKED, TRUE); // optional check mark
Then use...
ListInsertItem (RFL.FilePathList, pathname, FRONT_OF_LIST);
ListInsertItem (RFL.FileMenuList, display_path, FRONT_OF_LIST);
ListInsertItem (RFL.FileMenuID, &entry_ID, FRONT_OF_LIST);
I also used ListGetPtrToItem, ListNumItems, ListInsertItem and ListRemoveItem.  If you read the help info for these, their application should make sense.  'Normal' windows-based applications save their recent file list in the Windows registry, but I avoided this by simply writing all strings to a text file in the application's directory. (much simpler and safer for apps that may not be installed with an installation program!)
John.
(3,340 Views)
You might also be looking for something like the Path Control (toolslib\custctrl\pathctrl.fp).  The path control keeps a history of the paths you enter in the control and you can press the up/down keys to navigate through the list.
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(3,329 Views)
