LabWindows/CVI
h file to fp conversion issue
I am using h to fp conversion tool available in CVI 7.1. (Options\Generate Function Tree from h file)
//int CVIFUNC  my_function(int* temp);   //Does not work
int CVIFUNC  my_function(int *temp);     //Does work
Any comments?
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(3,589 Views)
I reproduced this as well. I'll file a bug report for this.
Thanks for letting us know.
Bilal Durrani
NI
(3,563 Views)
void* STDCALL my_function(void *buffer, int value1, int value2);  //does not work
void *STDCALL my_function(void *buffer, int value1, int value2);  //does not work
void STDCALL my_function(void *buffer, int value1, int value2);  //does work
is void * not supported? I see it is available from function panel menu.
I am trying to create fp from h file and I am getting unknown data type error.
Thanks.
CVI 2010
LabVIEW 2011 SP1
(3,531 Views)
Hello Sheetal,
You need to have a space on each side of the "*":
void * STDCALL my_function(void *buffer, int value1, int value2);
Hope this helps and good luck with your application!
Shakhina P.
(3,499 Views)
Thanks for your help.
Try this
/// OUT 1
int STDCALL my_function(char * value); //give an error
/// OUT 1
int STDCALL my_function(char *value); //works fine
Thanks.
CVI 2010
LabVIEW 2011 SP1
(3,488 Views)
