LabWindows/CVI
"Find" - Dialog freezes CVI ?
hi all
using CVI 9 since some days the following behaviour appears:
If I want to change the "directory" in the search-window (started from inside a source-window by Ctr+F) CVI freezes and i have to kill it by the task-manager. any idea ?
best regards
Simon
(3,147 Views)
Mine works fine. What OS and service packs are you running?
Jattie van der Linde
Engineering Manager, Software & Automation
TEL Magnetic Solutions Ltd
(3,107 Views)
hi,
->the OS is a XP Prof with SP 3
->CVI 9.0.0
this can' t be a generally bug, because the search worked fine till some weeks ago. but now the effect takes place in 50% of changes of the search path.
best regards
Simon
(3,104 Views)
Hi Simon,
please reinstall your CVI an try it again.
I think this is the best solution at the moment.
Phanuel
(3,060 Views)
