LabWindows/CVI
printing a graph with NIReports
Hello. I am generating a report using the reportgen.fp driver and I've ran into a snag. I need to print a graph that I generated on one of my panels. I thought of using the NIReports_AppendImageFile, but the graph is not a bitmap. Is there any way of display this graph in my NIReport? Any suggestions would help.
Jason
(3,223 Views)
Use the GetCtrlBitmap to get a bitmap of the graph, then use SaveBitmapToFile (in the programmer's toolbox) to save the bitmap to a file. Then you can put it in the report.
Best Regards,
Chris Matthews
(3,223 Views)
That works fine, but is there any way to use a clipboard function to perform this. I don't want to save the bitmap to a file. I was hoping to someone store this bitmap temporarily and then discard it after the report prints. Thanks for your help.
(3,223 Views)
No, you need a file for NI-reports. Just delete the file when your done (DeleteFile function).
Chris
(3,223 Views)
