pass data back through the (void*)callback
ray123
Member
I'd like to pass data back through the (void*) callback data variable to the calling function without using global variables.  Could you please show me sample code which assigns a value to the *callback data  (within the callback) thus allowing it to be passed back to the calling function
2 REPLIES 2
JonathanN
NI Employee (retired)
Re: pass data back through the (void*)callback
Message contains a hyperlink
Hi ray123,
Check out the Using the void *callbackData Parameter in Callback Functions KnowledgeBase and the Callback Data Example in CVI example for help. Basically you will be using the SetCtrlAttribute function with the ATTR_CALLBACK_DATA attribute which will allow you to assign the callback data pointer to some user data.
Hope this helps!
Best Regards,
Jonathan N.
Highlighted
Guillaume Dargaud
Active Participant
I often use it to pass single integers without using pointer logic.
In the calling code:
PostDeferredCall(cb_ReceivedControl, (void*)(Card<<8 | usbData[0]));
In the receiving code:
static void CVICALLBACK cb_ReceivedControl(void *callbackData) {
int Card=(int)callbackData>>8;
char Data=(int)callbackData&0xFF;
Guillaume Dargaud
http://www.gdargaud.net/
