LabWindows/CVI
Showing results forĀ
Search instead forĀ
Did you mean:Ā
parse string using CVIXML
HI,
I am familiar with the CVI XML libraries, in that i have been reading from and writing to XML files.
now, i just want to be able to parse XML Data using the CVI XML functions without using actual files.
Specifically, I have a stream of XML data buffered into a string, and I want to parse through its elements and attributes.
how can this be done?  i cant seem to find any way to load a CVIElement without assuming a CVIDocument exists.
thanks!
(4,318 Views)
This is currently not available in the CVIXML instrument. But you can add a new function to do this in cvixml.c quite easily by creating a function similar to CVIXMLLoadDocument and replacing the MSXML_IXMLDOMDocumentload call with a call to MSXML_IXMLDOMDocumentloadXML. You will also have to declare the new function (say CVIXMLLoadXML) in cvixml.h and optionally add a function panel for this in cvixml.fp, and finally recompile the instrument.
(4,297 Views)
hmmm   that sounds like a weekend project
Smiley Wink
ill try it out and come back.
(4,262 Views)
