LabWindows/CVI
open ini file
hello,
i have a little problem ans hope everyone can help me.
I would like to open a *.ini file if I press the button, but the file does not open. can somebody please help me?
int CVICALLBACK LoadFile(int panel, int control, int event,   void *callbackData, int eventData1, int eventData2)
         switch (event)
              case EVENT_COMMIT:
                   OpenFile("c:\\home\\My Documents\\studium\\File.ini",VAL_READ_WRITE,VAL_OPEN_AS_IS,VAL_ASCII);
                   break;
        return 0;
(3,995 Views)
Accepted by topic author Axinia
i am not sure, what do you expect the OpenFile() function to do ?
OpenFile() opens the file in a programmatic manner: it means that it makes available a value (that you should store in a variable) which allows you to read or write data to/from the file bycalling file manipulation functions like ReadFile() or WriteFile(). it will NOT open the file in your favourite editor !
to open the file in the Windows user Interface meaning of the word, use the function OpenDocumentInDefaultViewer().
(3,981 Views)
Hi Axinia,
What do you actually want to do when the button is clicked?
Do you want to open a seperate text viewer (like notepad) to see the contents of the file or do you want to read the contents of the file into a string?
The solution depends on your answer.
The code you have provided actually opens a file to be read/written, but you have to assign the return value to a variable in order to access it later.
int fileHandle;
fileHandle = OpenFile (...);
Hope this helps,
S. Eren BALCI
IMESTEK
(3,980 Views)
thx dummy_decoy
exactly this I have looked 🙂
(3,978 Views)
