LabWindows/CVI
nsp.h Intel signal processing Library
Has anyone used Intel signal processing Library (NSP) with LabVIEW? If would it be possible to provide the nsp.h header file?
From what I know it has been discontinued but I have a really important old project that requires it to work. Is there a work around since the code uses nsp library but it's no longer available how can I get it to work?
(1,564 Views)
You have ended up posting this question to the CVI board. Either repost it to the LabVIEW board or ask a moderator to move it to the correct board.
(1,522 Views)
I'm sorry it's my mistake i intended to ask if anyone has used it with Labwindows/CVI. I made a typing error there. Can you please help?
(1,520 Views)
It’s a bit hard to keep track of the various Intel projects. But it seems very likely that such a library was eventually incorporated into the Intel Math Kernel Library if it was useful at all. Of course the MKL is by now part of the Intel One API initiative but it is also the base of the LabVIEW and LabWindows Advanced Analysis Library. It may be more useful to look into porting your code to use this library than trying to track down an old and obsolete one that may or most likely may not run on your Windows 11 system with 13th generation Intel CPU.
Rolf Kalbermatter  My Blog
(1,507 Views)
