LabWindows/CVI
Help regarding Lab windows CVI
I am trying to build a CLI exe written in C through Lab Windows CVI. It builds successfully with some warnings. I want to spawn that through JavaScript and process the output of that with JavaScript itself. The CLI exe when called displays some "Non-fatal runtime errors". Do you guys have any idea how can I remove them or prevent them from displaying.
(1,130 Views)
Well, the only solution is to fix your runtime errors. Seriously.
Also make sure [Build][Target Settings] is set to [Create console application], and you can also SetStdioWindowOptions (, 0, ); and SetStdioWindowVisibility (0);
But seriously, debug your program and fix the errors.
(1,111 Views)
