11-11-2009 03:41 AM
I am using sqltoolkit. It works very good on remote, but I have a problem when I try to work on my PC ( localhost )
I am using Mysql server 5.0 , and when I try to connect I got this message:
"Client does not support authentication protocol requested by server;consider upgrading MySql client"
I am using this parameters to connect SQL:
#define SQL_SERVER "localhost"
#define SQL_USER "username"
#define SQL_PASSWORD "mypassword"
#define SQL_DBNAME "dbname"
Do you have any idea?
Daniele
11-12-2009 09:59 AM
Hi Daniele,
you stated that your program run on remote: what exactly do you mean? Which parameters did you use on the remote PC?
Are you able to run CVI examples and correctly connect to a database?
What did you install on the different PCs?
Bye,
Licia
11-12-2009 10:11 AM
Ciao Licia,
With remote I mean that my application is able to connect to mysql database on remote server, but when I try to connect with Mysql server on my PC doen't work and I got the message error wrote above. MySQL server (version 5.0) work correct with other application (i.e. Web application ) but not with my CVI app.
Ciao
Daniele
11-12-2009 10:14 AM
Ciao Daniele,
MySql server is the same?
Licia
11-12-2009 10:20 AM
11-12-2009 10:26 AM
I'm sorry, I meant the version...
Bye!
Licia
11-12-2009 10:29 AM
MySQL server 5.0 on both system I mean.
I am sorry for my imprecision
Daniele
11-13-2009 09:32 AM
Are you able to connect up to it using the MySQL Browser? If you use a Web application it is going through the Apache server, not directly to the MySQL daemon. Are you using the MySQL API or NI SQL Tool Kit?
Mike
11-13-2009 10:47 AM
Hi Mike,
I don't use API, but NI SQL Tool Kit.
For my web application I use Apache and PHP and work without problem on localhost.
When I set in my CVI app the parameter for MYSQL connection on LOCALHOST I received the error wrote above...
Daniele
