LabWindows/CVI
multiple lines of text on a command button
Is there a way to get multiple lines of text on a command button.  Instead of a wide button with the text " Start Test System".  I would like a tall button with 3 line.
  Start
  Test
System
(5,998 Views)
While editing comman button label in the UIR editor you can split text into lines with Ctrl+Enter.
If you are setting the label programmatically, embed '\n' code into the label text.
Both methods work for all control types, not only for command buttons.
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(5,991 Views)
Thanks, I thought it would be simple.
(5,968 Views)
