LabWindows/CVI
memory leak
hello guys,
I want to know  CA_FreeMemory(); really free the memory.
For eg:
   char* seqName=0;
  TS_SequenceGetName (Sequence_Obj, &errorInfo, &seqName);
   if (seqName)  CA_FreeMemory (seqName);
I see that seqName still has some address after executing CA_FreeMemory (seqName);
Any clarifications appreciated.
Jis
(3,028 Views)
Even I am facing the same problem with "CA_Freememory". In the below code the memory allocated to the pointer "sequencename" from the function callTS_SequenceGetName" doesn't get freed even after calling the "CA_Freememory".  Please can anyone suggest the work around for this error.
#include <cviauto.h>
#include "tsapicvi.h"
#include <utility.h>
#include"test.h"
int __stdcall DllMain (HINSTANCE hinstDLL, DWORD fdwReason, LPVOID lpvReserved)
 switch (fdwReason)
  case DLL_PROCESS_ATTACH:
   if (InitCVIRTE (hinstDLL, 0, 0) == 0)
    return 0;   /* out of memory */
   break;
  case DLL_PROCESS_DETACH:
   CloseCVIRTE ();
   break;
 return 1;
int __stdcall DllEntryPoint (HINSTANCE hinstDLL, DWORD fdwReason, LPVOID lpvReserved)
 /* Included for compatibility with Borland */
 return DllMain (hinstDLL, fdwReason, lpvReserved);
int __declspec (dllexport)  __stdcall getcontext(CAObjHandle thiscontext)
 TSObj_Sequence newobjt=0;
 char *sequencename=NULL;
 ERRORINFO errorInfo;
 TS_SeqContextGetSequence(thiscontext,&errorInfo,&newobjt);
 TS_SequenceGetName(newobjt,&errorInfo,&sequencename);
 CA_FreeMemory(sequencename);
 return 0
(3,006 Views)
