LabWindows/CVI
long long multiply - (64-bit * 64-bit) to 128-bit result
In CVI when multiplying two 64-bit integers the result by default is the lower 64-bits of the multiply.
Is there an easy way to get the upper 64-bits?
Tx,
Matt
(3,744 Views)
maybe this code helps: (I did not try it)  https://www.codeproject.com/Tips/618570/UInt-Multiplication-Squaring
(3,712 Views)
Splitting the long long up into 2 longs and doing 4 long multiplies and adds is what I had been doing.  I was hoping that there was some CPU instruction that I could get at that would give me the upper product directly which would really cut the computational time of extended arithmetic dramatically.  Apparently there is not, since I can't find any reference to it on my others searches.
Tx,
Matt
(3,681 Views)
Yeah unfortunately I think splitting it up into two 32-bit then performing 4 multiplication operations is probably going to be your best bet as CVI doesn't have built-in functionality for this and doesn't support 128-bit numerics.
Applications Engineering
(3,668 Views)
