07-23-2018 01:36 AM
For a school project I need to communicate my laptop camera.
It doesn't have a .dll file ,
All I know is that I would probably have to do this with activex.
can I have some guideness on how to create the connection between activex and laptops camera
thanks in advance
07-24-2018 09:19 AM
Yes, you would probably have to do this by integrating an ActiveX control in CVI. I've provided some links below that may help you learn how to integrate ActiveX controls.
"Audio recording LabWindows/CVI" (useful info about ActiveX controls with a webcam though): https://forums.ni.com/t5/LabWindows-CVI/Audio-recording-LabWindows-CVI/td-p/3250706
"ActiveX control overview": http://zone.ni.com/reference/en-XX/help/370051V-01/cvi/uiref/cviactivex_control_overview/
"Programming with ActiveX Controls": http://zone.ni.com/reference/en-XX/help/370051AG-01/cvi/uiref/cviprogramming_with_activex_controls/
Hope this helps!
07-24-2018 10:28 AM
Thank you very much
do you know what is the name of the control I need to add In order to control my laptop camera ?
07-25-2018 11:53 AM
I had some trouble finding info on this for working with C as most of the examples are related to .NET. However, I stumbled across this forum post which also provides a lot of good resources for how to set this up in LabWindows.
This KB especially seems helpful as it outlines how to use the ActiveX Controller Wizard to Generate Code in LabWindows/CVI
