LabWindows/CVI
load o picture on file using imaqReadFile
 I try to load a picture into my CVI programm with above code,but also failed.
    for ( i = 0; i < NUM_OCR_IMAGES; i++ )
         ocrImagesArray[i] = imaqCreateImage (IMAQ_IMAGE_U8, 10);
    imaqReadFile( ocrImagesArray[i], "OCR", NULL, NULL );
i try to load images on folder nam OCR in this array ocrImagesArray[i] like loop
but there is error i try ti use this code too but without succes
 //imaqReadFile( ocrImagesArray[1], "OCR\\Image %d%d.bmp", NULL, NULL);
all my image in this folder are names Image 00 Image 01 ....... .bmg
thks for help
(3,474 Views)
Hello Bylka,
Did you try using a simple project shipped with CVI?
C:\Users\Public\Documents\National Instruments\CVI\Samples\Vision\1. Getting Started
have a nice day,
M-Junior
(3,432 Views)
Hello
yes I have already seen the example but in my case I want to use the function  imaqReadFile  while taking as a parameter not an image but an array of images with the name of the folder where my images are
thank you
(3,427 Views)
Ok thank you Bylka.
In that case, why don't you use a for loop with the array of images in input and the imaqreadfile inside the for loop? This way you can create an array of reference with all the pictures.
M-Junior
(3,421 Views)
Hello M-Junior, thank you for answering me
at begining i do this and its work without error
    /* Create all global images */
    for ( i = 0; i < NUM_OCR_IMAGES; i++ ) {
    /* Load all the OCR images */
    imaqReadFile( ocrImagesArray[0], "OCR\\Image 00.bmp", NULL, NULL);
    imaqReadFile( ocrImagesArray[1], "OCR\\Image 01.bmp", NULL, NULL);
    imaqReadFile( ocrImagesArray[2], "OCR\\Image 02.bmp", NULL, NULL);
    imaqReadFile( ocrImagesArray[3], "OCR\\Image 03.bmp", NULL, NULL);
    imaqReadFile( ocrImagesArray[4], "OCR\\Image 04.bmp", NULL, NULL);
    imaqReadFile( ocrImagesArray[5], "OCR\\Image 05.bmp", NULL, NULL);
    imaqReadFile( ocrImagesArray[6], "OCR\\Image 06.bmp", NULL, NULL);
    imaqReadFile( ocrImagesArray[7], "OCR\\Image 07.bmp", NULL, NULL);
    imaqReadFile( ocrImagesArray[8], "OCR\\Image 08.bmp", NULL, NULL);
all images on this file its shown on my interface
but when i try to do somthink lik standar without mentioning all the photos on my folder like this
    imaqReadFile( ocrImagesArray[i], "OCR\\Image 0.%d.bmp", NULL, NULL);
i have error
NON-FATAL RUN-TIME ERROR:   "OCR.c", line 118, col 5, thread id 4004:   Function imaqReadFile: (errorCode == -1074395995 [0xbff604a5]). File not found.
i dont know what i can make here that my code understands that they have to take the photos found in the OCR folder;
imaqReadFile( ocrImagesArray[i], "OCR\\...............bmp", NULL, NULL);
thks for help
(3,411 Views)
Accepted by Bylka
    Hello
i do this modification and it's work
        for (r=0; r <10; r++)   {
    sprintf(nom, "OCR\\Image %02hu.bmp", r);
    printf("nom=[%s]\n", nom);
    imaqReadFile( ocrImagesArray[r], nom, NULL, NULL);
thks
(3,367 Views)
