‎02-19-2015 06:50 PM
I am running CVI 2012. In the last few days whenever I start CVI, it INSISTS on wanting to install NI LabVIEW Run-Time Engine 8.2.1. I don't know how to load this element. If I just cancel out of the install attempt a few times, then CVI starts normally, and everything seems to work. I have also run the NI update manager, it installed a new LabVIEW runtime module, but this DID NOT fix the problem. I also don't know why it wants to install the LabView Run-Time engine. I am not running LabVIEW. I have reviewed some related posts, but none seem to be relevant to my issue. Please advise course of action to fix. Thanks !!
‎02-20-2015
10:29 AM
- last edited on
‎07-28-2026
03:27 PM
by
Content Cleaner
Did you install or update any CVI component in the last few days? If you are unsure of that, you can check the Installation Log generating a MAX Technical Report. Is the project you are trying to open using the Signal Processing Toolkit?
MCOTO
‎02-23-2015 11:12 AM
I checked the Measurement and Automation Explorer and the Labview 8.2.1 run-time engine shows as installed, and it seems to be present in the correct directory. However, every time I start CVI, it wants to install the 8.2.1 RTE. Kind of annoying. If I invoke "find examples" which uses the Labview RTE, it also first prompts to install the RTE. If I cancel that out, finding examples still works fine. The whole bevahior is a head scratcher !! Please advise if any ideas come to mind. Thanks.
‎02-23-2015 11:18 AM
Problem fixed. Thanks for your reply !!
