LabWindows/CVI
how to write Date/Time property of tdms file
On the root page of the tdms file, there is a built-in property called "Date/Time" in the first row.
I would like to use it to save the time stamp when the tdms file is created. But in the help file,
I only find the following property constant. So, how can I write to the "Date/Time" property field?
Property Constant Data Type
Name TDMS_FILE_NAME String (char *)
Description TDMS_FILE_DESCRIPTION String (char *)
Title TDMS_FILE_TITLE String (char *)
Author TDMS_FILE_AUTHOR String (char *)
Thanks for any idea or suggestion.
(10,114 Views)
Accepted by topic author Marg_SZ
Not sure if this is exactly what you want, but have you tried this?
CVIAbsoluteTime			CVItime, *t = NULL;
TDMSFileHandle			deH = 0;
// Create TDMS file and set some properties
errChk (TDMS_CreateFileEx (file, TDMS_Streaming2_0, TDMS_ByteOrderNative, 0,"example.tdm", "someText", "title", "author", &deH));
GetCurrentCVIAbsoluteTime (&CVItime);
errChk (TDMS_SetFileProperty (deH, "Date/Time", TDMS_Timestamp, CVItime));
// Save and close file
errChk (TDMS_SaveFile (deH));
TDMS_CloseFile (deH);
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(10,094 Views)
Thank you for replying.
I tried your suggestion and it did save a property field "Date_Time" with date time value even though you passed "Date/Time".
I don't know how to write to the built-in property "Date/Time". NI engineers designed this property field but did not tell user how to use it.
Appreciate your help.
(10,081 Views)
You're right, I noted this when I wrote the code I posted here a few years ago.
I can add that all non-alphabetic characters (including spaces) are translated by TDMS functions to unserscores: for example, if I write a file property named "Supply (V)" it will be saved as "Supply__V_".
This is not declared anywhere in the documentation for TDMS library functions but in my opinion it should be.
(10,063 Views)
Hi, I had also same question.
Date/Time value on header of the TDMS file is written "naming" it DateTime; without the slash and no space between both words. I find it a little bit weird but it works.
At least, value is read correctly on Excel using the TDMS add in and also using the TDMS - File viewer.vi
Small example:
DateTime TDMS
Hope it helps!
Ben
(9,897 Views)
Yeah....  I got it right.  Thank you for help, Ben.
(9,887 Views)
