キャンセル
次の結果を表示
次の代わりに検索
もしかして:
how to call a button’s click event programmatically
解決済み
解決策を見る
Dear All,
I would like to know how to call a button’s click event
programmatically in LabWindows/CVI.
Thank you very much,
Mariela.
0 件の賞賛
メッセージ1/5
7,360件の閲覧回数
解決策
受理者 prodna
Either you directly call the button callback or (better) use CallCtrlCallback passing the appropriate event (normally EVENT_COMMIT: it depends on which event you are handling inside the control callback).
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
メッセージ2/5
7,355件の閲覧回数
I have a follow up question.
the prototype is
int CallCtrlCallback (int Panel, int Ctrl, int Event, int EventData1, int EventData2, int *Return_Value);
For an event = EVENT_COMMIT what are the meaning of values EventData1 and EventData2? Or do I just set them to NULL?
0 件の賞賛
メッセージ3/5
7,270件の閲覧回数
I have never checked what the values are when I get an EVENT_COMMIT event but I have used this function and simply set both of those to zero.
Works fine, I do know that for mouse clicks (not commits!) those are populated with the mouse pointer coordinates.
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
0 件の賞賛
メッセージ4/5
7,247件の閲覧回数
Meaning of eventData parameters is listed in userint.h where events are defined. Several events have associated eventData values (some of them only when fired for specific control types).
メッセージ5/5
7,245件の閲覧回数
