LabWindows/CVI
graph labellling
I am using CVI 6 for our application development. I am plotting some data on graph control. X axis is time scale for our data. I want to label x axis of my graph with time stamp (HH:MM:SS) as follows: "12:10:20". Which function or property of graph control I can use for doing this?
cheers
Niranjan
(3,507 Views)
You can use CWGraph control, which is an ActiveX control from NI. You can open the properties page, and change the x-axis format.
(3,507 Views)
I use CWGraph for plotting data instead of StripChart because I can have a X axis in date/time format, cursor( impossible with a stripchart), annotations, a Y axis per plot...It's very powerfull, but delicate to programm with CVI.
(3,507 Views)
