LabWindows/CVI
fonts not supporting
Hello sir,
               Im copied character from charater map from PC and pasted in Edit command panel Label. bu its not supporting its giving ? qusetion mark insted of symbol.
(4,621 Views)
You are copying from a Unciode character set, but LabWindows/CVI does not suport Unicode. If you need mutlilingual capabilities it is possible with mutlibyte character sets, but for other specialized symbols you likely will need to use an image on the control instead of a font.
--Ian
(4,545 Views)
