LabWindows/CVI
error Undefined symbol
I'm using CVI2013 on Win7.
I have a DLL project proj1.dll where I declared a function "GetExxotestList" like this :
int __attribute__((overloadable)) GetExxotestList (int *NbCardUSB, int *NbCardPCI, struct DEVICE *Device[8])
DEVICE is a struct declared in the same .c file like this :
struct DEVICE
	unsigned long d;
In the .h file of this project, I declared only the function prototype like this :
int __attribute__((overloadable)) GetExxotestList (int *NbCardUSB, int *NbCardPCI, struct DEVICE *Device[8]);
And I compile it with no errors.
Now, in the Main project (executable) I wanted to call this function inside a callback function, so I did like this :
int CVICALLBACK Refresh_Exxotest_Panel_CB (int panel, int control, int event,
			void *callbackData, int eventData1, int eventData2)
	int NbExxoCardUSB = 0;
	int NbExxoCardPCI = 0;
	struct DEVICE *Device[8];
	switch (event)
		case EVENT_COMMIT:
			//Update exxotest list
			GetExxotestList (&NbExxoCardUSB, &NbExxoCardPCI, Device[8]);
			break;
	return 0;
In the Main project, I added the .lib and .h files of the dll project.
The problem is when I try to compile the Main, I have this link error :
error: Undefined symbol '__Z15GetExxotestListPiS_PP6DEVICE' referenced in "c:\ProjectX\Sources\Main\cvibuild.Main\Debug\Main.obj".
I can't undrestund why !
What is weird too, is that "Z15" and "PiS_PP6" labels are added automatically in the error message, I don't know what is it.
Please advice,
best regards,
Houssam
(6,334 Views)
Hi Houssam,
You need to define the struct definition in the header file so that the external code module, or your main program can see that struct definition.
(6,279 Views)
Accepted by topic author HoussamAz
Hello
int DLLAPI __stdcall GetExxotestList (int *NbCardUSB, int *NbCardPCI, struct DEVICE *Device[8]);
int __declspec(dllexport) __stdcall GetExxotestList (int *NbCardUSB, int *NbCardPCI, struct DEVICE *Device[8])
(6,261 Views)
Hello houssam;
i have the same probleme when i compil without error but whene i debug i have this error i dont know why im using labwindows cvi 2017
error :
Build Status (OCR.prj - Debug)
 Link OCR Example_dbg.exe
  error: Undefined symbol '_DisplayError' referenced in "c:\Users\i87278\Desktop\OCR exp\cvibuild.OCR\Debug\OCR.obj".
Build failed.
do you have any idea of this problem
thks
(5,456 Views)
Hello Rose,
You may have to change the function declaration of "DisplayError" as I did.
If this function is declared in another project, make sure that you included the header file (.h) and the object (.lib) in the OCR project.
(5,452 Views)
i include all the floder header but there are no object .lib what is it exactly
thks
(5,444 Views)
