LabWindows/CVI
easytabs and timers
I run into a problem with CVI:
I have a main panel with some EasyTabs on it and also a Timer (which is placed on the main panel, not on one of the easytabs...).
The timer is set to every 100 miliseconds, and sends a message (like 20 bytes) over the serial RS232 port.
The problem occurres while the application is running and I am leafing through the tabs, after a short while the application breaks at RunUserInterface(). and reports FATAL RUN TIME ERROR.
I believe there is a connection between the easytabs and the timer because when I disable only the timer (while the rest of the app. continues) it does not happend.
Any help?
Thanks.
(2,997 Views)
Usually in case of a fatal run-time error the program breaks into the source code in the line on error. You can have the corresponding options in the project menu set not to break: check Debugging options in the Build Options menu: it must be set to either Standard or Extended to have run-time checking enabled. Also, ensure that the Break on library errors check box is marked in Run options dialog in project window's Options menu; check also that either SetBreakOnLibraryError () and SetBreakOnProtectionError () functions are not called inside your code.
(2,984 Views)
Hello Disa,
To work around this issue, turn off "Break on Library Errors" either programmatically by calling "SetBreakOnLibraryErrors (0)" or manually by going to the Project Window >> Options >> Run Optins >> Break On Library Errors
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(2,964 Views)
