LabWindows/CVI
distribution naming/versioning
Is there a way to embed the version number into the name of the top-level folder containing the distro? Or do I have to manually rename it?
Also, can I change the "cvidistkit" that is prepended to the folder name?
Thanks.
(3,839 Views)
To my knowledge you have to rename the folder manually.
Yes, you can rename it, but the next distribution kit you generate again will be called cvidistkit
If you want this behavior changed you can suggest it here
(3,835 Views)
Accepted by mzimmers
I have to correct my previous statements: while it is not possible to include the file or product version in the folder name, it is possible to include the installer version. Checking auto-increment for the installer version will avoid overwriting the old folder.
This setting is found in the Edit Installer dialogue on the General page: for the output directory certain placeholders can be used such as %version for the installer version.
Sorry for the confusion...
(3,822 Views)
Hey, Wolfgang. That is EXACTLY what I was looking for.
I knew there was something like placeholders, but I didn't know the term for them. Is there a list of those available somewhere? Help didn't reveal much.
Thanks!
(3,815 Views)
Puh, I am relieved, my mistake is eliminated Smiley Happy
Yes, there is a list in the help, you won't believe it Smiley Wink
To get there: Build / Edit Distributions, on the General Tab press the Help button...
You can use the following variables in the path:
  • %name—The application name
  • %version—The version of the installer, specified in n.n.nformat
  • %major—The major version of the installer
  • %minor—The minor version of the installer
  • %maint—The maintenance version of the installer
  • %lang—The installer dialog box language, such as English
(3,812 Views)
Slick. This is great. Thanks again, Wolfgang.
(3,806 Views)
