LabWindows/CVI
disable XNET ack
I'd like to be able to turn off CAN acknowledge in my CAN tranceiver (PXI-8512) while continuing to transmit frames.  The purpose is to cause a bus error.  The property nxPropSession_IntfCANLstnOnly is almost what I need, however it prevents ack AND transmit.  Is it possible to just turn off the acknowledge of received CAN frames without turning off transmit frames?
(4,723 Views)
Hi, here you will find a better explanation of what that feature does. Setting that property to true will do the trick. I hope this helps Smiley Wink
Alejandro C. | National Instruments
(4,707 Views)
Your link is no longer active. What property or function were you suggesting?
(2,777 Views)
