LabWindows/CVI
device managing via labwindows
Hi
I'm doing a automatic bench test for testing cable modem. I'm communicate
with the modem via usb. Howerver, if I don't unplug the device without stopping it,the computer freeze up.
Is it a way, via labwindows, to manage device? I would like to stop the usb device automaticaly through my labwindows application before I power down my
modem.
Thank you
(2,788 Views)
You will need to refer to Windows SDK function calls for this. CVI has no built in functions for doing what you need, but im sure there are some Windows API calls that would do the trick. The Windows SDK is available with CVI (its not selected by default, you would need to run the installer again to enable that option)
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(2,788 Views)
